Old 08-06-2015, 12:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Cruise Control not working
Old 08-16-2008, 11:23 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
Originally Posted by atc250r
When I held both buttons (resume/accel AND set/coast) at the same time, the truck would almost hold the speed. Any suggestions here? Vacuum problem or switch related?
i'd say switch
Old 08-16-2008, 03:18 PM
atc250r's Avatar
atc250r
atc250r is offline
Well I removed the switches from the steering wheel and followed the directions in VWANDDODGE's link about how to disassemble and clean the switch. Great step-by-step post by the way. Reassembled everything and no difference- light comes on, but cruise won't catch. Any further advice?
Old 08-17-2008, 11:23 AM
HankL's Avatar
HankL
HankL is offline
there is a vacuum test port on the passenger side.
you could remove and plug the vacuum line going to the cruise control solenoid underneath the battery, and run a temporary vacuum line from the test port nipple to the cruise control solenoid.
if the cruise began to work again
that would indicate you need to carefully work backwards down the original vacuum line to the cruise control looking for the leak
good luck
Old 08-17-2008, 11:10 PM
atc250r's Avatar
atc250r
atc250r is offline
Ok HankL, I'll give that a try. I know now that it is a vacuum leak, as my A/C goes from vent to defrost when under load.
Old 08-18-2008, 12:17 PM
atc250r's Avatar
atc250r
atc250r is offline
I removed the battery and the tray, and yeah vacuum hose is broken in 2 places- right at the elbow, and about 2 inches away from that. Dodge dealer quoted me $16 for a new vacuum line harness they call it, including the elbow. Ready to plug in at both ends. Pretty reasonable I'd say, or is repairing it better?
Old 08-18-2008, 01:09 PM
Gary-L's Avatar
Gary-L
Gary-L is offline
That's your call. I'd say go ahead with the dealer part in this case unless you can make do with something better.
Old 08-19-2008, 02:07 PM
atc250r's Avatar
atc250r
atc250r is offline
Problem solved after spending a whopping $3.25 on vacuum hose and an elbow. You guys rock! The help and diagnosis was very much appreciated.
Old 09-03-2008, 12:27 PM
bdasinger88's Avatar
bdasinger88
bdasinger88 is offline
Default 2005 ram cruise problem
I have a 2005 ram 1500 4x4 and my cruise stops workinf at 65 mph, but it works fine below 65. Any suggestions?
Old 09-03-2008, 12:50 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
bdasinger88 , you would be a lot better off posting your prob in the third generation section.
Old 02-07-2013, 10:12 AM
Foster's Avatar
Foster
Foster is offline
I am having a similar problem with my Dodge ram 1500, 1998 model. The light comes on the cruise control engages when I press the button and set the speed, but about 60 seconds later it disengages as if it were turned off. Then it does not come back on again. All hoses of been checked, no vacuum leaks, all hoses of been replaced. Any suggestions?
Quick Reply: Cruise Control not working
