Radiator drain plug clogged?
Old 12-05-2008, 08:03 PM
pcfixerpro's Avatar
pcfixerpro
pcfixerpro is offline
bottom drivers side of rad
Old 12-05-2008, 09:44 PM
ophidia's Avatar
ophidia
ophidia is offline
Look straight down from the upper radiator hose-- you'll see a plastic tab sticking out down at the bottom. That's the valve. The nipple you connect the tubing to is on the bottom of that. I think what I used was 3/8" ID tubing but I'm not 100% on that.
Old 12-06-2008, 12:06 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
the drain plug works kind of weird. you unscrew it a half round or so, and then pull out about 3/4 inch.
the block drain plugs are on each side of the engine, tucked in behind the motor mounts. be careful with them, they'll round off easy. mine wanted to round off, so i clamped a good pair of vice grips on them, then put a short pipe over the end for more leverage. that worked. when re-installing, use some rtv or teflon and do not overtighten. snug is good enough.
Old 12-08-2008, 06:06 PM
SoCal_Ram's Avatar
SoCal_Ram
SoCal_Ram is offline
The radiator drain is on the bottom left side. The engine block plugs are under the exhaust headers.
Old 02-02-2011, 09:31 PM
notamechanicintexas's Avatar
notamechanicintexas
notamechanicintexas is offline
Default same problem
Well I'll be darned...I had the same problem it would not drain that is how i came to this thread....I will try to pull it out tomorrow.
Old 02-02-2011, 09:37 PM
grox's Avatar
grox
grox is offline
Just pull the lower hose with the engine running and the radiator cap off. Flush it out by: reattaching hose, filling radiator, wait for thermostat to open, pull lower hose, and repeat.
Old 02-02-2011, 10:44 PM
99dodge318's Avatar
99dodge318
99dodge318 is offline
our motors have block drain valves? never knew that. also never looked. lol i just remove lower hose, drain rad, flush with water hose, attach lower hose & fill rad, start truck for 10 mins, drain again then top off 50/50 with anti-freeze and water
Old 02-02-2011, 11:16 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
Not valves... but, 'plugs' you can remove at the bottom of the water jackets on each side of the block. Well, at least, according to popular theory you can remove them.... in actual practice, not so easy......
Old 02-03-2011, 01:43 PM
Saber6's Avatar
Saber6
Saber6 is offline
I'm glad I read this! I figured mine was clogged. I twisted it and it stopped at about a half turn. I was pretty sure it would have broken if I turned harded. I didn't think to give it a pull. And... drain plugs on the block? I didn't know that either.
You guys are teaching me gobs of stuff about this truck. You are saving me lots of $$$. (And... No, I'm not sending you your cut of my savings!)
Old 09-28-2011, 05:39 PM
FreeDodge's Avatar
FreeDodge
FreeDodge is offline
This helped getting my drain plug out but now I can't get it back in. I am pushing/screwing in so hard I am worried I am going to break the plastic plug. I also even looking at the service manual can't find the drain plugs on the block =(
Quick Reply: Radiator drain plug clogged?
