46re Transmission Problems
Old 02-09-2009, 05:26 PM
95MaroonMonster's Avatar
95MaroonMonster
95MaroonMonster is offline
your converter could be taking a crap on you
but idk
Old 02-10-2009, 01:45 PM
MonteC's Avatar
MonteC
MonteC is offline
Replace your governor pressure sensor and solenoid.
Old 02-11-2009, 10:44 AM
shawngrace5's Avatar
shawngrace5
shawngrace5 is offline
Okay will do, thanks for the advice guys, I appreciate it
Old 02-11-2009, 12:05 PM
padodgeram's Avatar
padodgeram
padodgeram is offline
also make sure your check valve is not getting cloged or blocked . clean , replace or dont use it at all..
Old 12-16-2009, 12:11 AM
jaimeskota's Avatar
jaimeskota
jaimeskota is offline
Default missshift on 46re
i own a 99 dakota with a 46re trans got it as a trade cause the tranny supposdly didnt work before taen it to the mechanic i decided to remove the oil pan and the oil filter before putting it back together theres a flat plate with four screws holding it together took it apart and notice a broken spring went to the junk yard got another one and truck runs like a new one before u guys take ur truck to the shop check that out if its missshifting or not shifting at all like mine and that could be the only problem ur truck has maybe a factory recall i dont but i noticed in two trans at the junk yard with the same issue badjeeptoy@yahoo.com hit me up and i could send a pix where that place is located exactly
Old 12-16-2009, 05:08 PM
codyselcamino's Avatar
codyselcamino
codyselcamino is offline
wonder if you can swap in a 47re? that should hold up to a 5.2 or even 5.9
Old 12-16-2009, 07:33 PM
Augiedoggy's Avatar
Augiedoggy
Augiedoggy is offline
guys this thread is from almost a year ago...I think he resolved his issue by now...
Old 12-16-2009, 08:19 PM
jeffwpayne's Avatar
jeffwpayne
jeffwpayne is offline
let's bring it back ...will a 47 tranny bolt up to a 5.9 and would it even be worth it??
Old 12-17-2009, 02:04 PM
codyselcamino
i was told that the 46re was equivalent to the 904, and the 47 was the 727, i got a 727 in my scout and that thing is bullet proof, if it would work i think it would be worth it
Old 12-17-2009, 08:51 PM
J415's Avatar
J415
J415 is offline
Go figure, NOOBS resurrecting old threads!!!
Quick Reply: 46re Transmission Problems
