Timing chain cover coolant leak
Old 04-21-2009, 09:59 AM
olyelr's Avatar
olyelr
olyelr is offline
Huh, well I just removed the big bolt very easily with an air impact, but I do not have any bolts holding the pulley on my balancer... nothing. Just a rubber looking seal all the way arounnd it. Is it pressed on there? It is a 2000 5.9.
Well, i supose I will head back out and see if I can use the puller to take it off... just dont want to break anything
  #32
Old 04-21-2009, 12:09 PM
01dabram20's Avatar
01dabram20
01dabram20 is offline
olyelr, it takes a three jaw puller. I just did mine over the weekend. You just have the one big bolt holding it on which is 1 1/4 socket. pull from the enter lip by the bolt threads.
  #33
Old 04-21-2009, 04:00 PM
olyelr's Avatar
olyelr
olyelr is offline
Yep, thanks. I pulled it all off at once (pulley and balancer seem to be one unit on mine) with the 3 jaw puller... went like butter. I left the bolt threaded in partially and screwed the puller bolt on that. Worked great.
  #34
Old 07-11-2009, 10:08 PM
RTEddie's Avatar
RTEddie
RTEddie is offline
New to the site, but I too am in the middle of changing my water pump on my 1999 Dodge Dakota R/T. Lots of good info here for me to use. Other than the pump, gasket, timing cover gasket, timing chain, radiator hoses, pump to engine hose, o-ring and maybe an oil pan gasket, anything else I need to change out? I don't want to do a complete engine rebuild or many performance mods (trying to conserve some cash), but I'm willing to change what's necessary and makes sense.
  #35
Old 07-12-2009, 12:28 AM
olyelr's Avatar
olyelr
olyelr is offline
Might as well do the Hughes or APS intake pan gasket repair kit too while you got the front half off. Thats what I did when I replaced my water pump.
  #36
Old 07-12-2009, 01:54 AM
Miami_Son's Avatar
Miami_Son
Miami_Son is offline
Originally Posted by dhvaughan
something like this is needed when using hand tools. not needed with air wrench.
FYI, you shouldn't use an impact or air wrench on this bolt. It is threaded directly into the crankshaft and the vibrations of an impact or air wrench can damage the crank bearings. It should be loosened with a breaker bar.
  #37
Old 07-12-2009, 06:07 PM
RTEddie's Avatar
RTEddie
RTEddie is offline
Default One step closer....
Well, I'm one step closer to having this massive job done. I got the clutch fan off the old water pump with a big crescent and (thanks to one of the tips I read on here) a strap wrench around the w.p. pulley. Now for the harmonic balancer. Mine had the removable crank pulley (leaving just the balancer). I'm paying careful attention to all the tips here. I hope I can get this off relatively easy.
  #38
Old 07-12-2009, 07:14 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
Do not tug on the outer ring of the balancer. If you do, you'll ruin the rubber inner ring that absorbs the crank vibrations. I believe the 5.9s used a 3 jaw puller. My 5.2 uses the same puller you use on a steering wheel.
  #39
Old 07-14-2009, 06:54 AM
RTEddie's Avatar
RTEddie
RTEddie is offline
Default Harmonic Balancer
Assuming I'm successful in removing this, what's the best way to re-install it? The puller sets I've seen don't seem to have something to put it back on with.
  #40
Old 07-14-2009, 07:06 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
to reinstall the balancer you simply put a light coat of oil or antiseize on the surfaces, line it up with the keyway and get it started. then tap it with a hammer and block of wood. when you get it all the way, or most of the way, put in the big crank bolt and torque the hell out of it. about 135# or something similar.
i haven't read this whole thread, but if you've got timing cover off, be sure and replace the front oil seal.
Quick Reply: Timing chain cover coolant leak
