1997 Dodge Ram 1500 Lifted!!!
#23
#25
#26
You can find kits on ebay that have 3" coil spacers and 2" blocks. Then purchase some shocks that are designed for a 2-3" lift. I bought mine from ruffcountry.com
I just did this on my truck and am very pleased with the results. I bought 285/75/16's but they would rub at full lock. I had to buy new rims to clear the tires.
Mine is a 99 ram sport 1500 ext. cab. heres a pic.
#28
So did the rims move the tire out of the wheel well a little bit? Can you explain?
Why wouldn't an AAL do the same thing as a block in the rear?
#29
An AAL will give you additional height, but, doesn't move the axle further from the spring. In fact, it makes the spring thicker, so it is more resistant to axle wrap. Keeps the stock geometry there...
#30
My steering is great, no issues from the spacers.
Yes Add a leaf is better than Blocks for sure. But does make the ride very stiff.
The kit I ordered came with the blocks so I just used them and they work great. The blocks with the kit came tapperd to maintain the correct angle for the axle and also came with pins so theres no way they could slip out.
Here is the kit I ordered
http://www.ebay.ca/itm/3-Front-2-Rea...item4d01738036
If you dont want to use blocks just order the spacers and the add a leaf seperate. Make sure you get extended shocks though.
The new rims had a negative offset which brought the whole wheel out a couple inches to make sure the tire would clear everything.
