Starts But Dies Unless I Give Gas - Won't Idle
Old 02-22-2010, 02:18 AM
Gnarkill666's Avatar
Gnarkill666
Gnarkill666 is offline
id still be careful with that battery might leave you stranded later on. i had the same thing happen a few years ago. i use to only drive my truck a few times a month when i had the boggers on it and it has a draw on it somewhere, if i forget to unhook the battery sometimes it dies sometimes its ok. jumped it one day wouldnt idle on its own, jumped it again kept my foot on the pedal for a few mins and it was good (so i thought) luckily the place i was going was sears lol. it was dead in the parking lot again they jumped it a few times but it wouldnt stay running at all that time couldnt even drive it. had to buy a new battery from them and havent had an issue again.
also i recently tried to charge that old battery again thinking i might have used to weak of a charger on it before, mainly because i only had that battery for a few months before the incident, (it wasnt an optima but it was a yellow top deep-cycle offroad battery) left it over night to charge and when i checked on it the next morning it was bubbling out the top. its one dead battery.
Old 02-22-2010, 08:08 AM
Kaldir's Avatar
Kaldir
Kaldir is offline
Same thing happened to me a year ago. I left my lights on and after getting a jump it would not idle at all. (I didn't help that this small 4 cylinder was what had to jump me.... took a while) This happened at work, so I just started the trek home and it took about 15 minutes of driving before it would idle like normal again. Its been a year, and have had no issues at all since then.
Old 02-22-2010, 08:57 AM
Me&MyMopar's Avatar
Me&MyMopar
Me&MyMopar is offline
I had a '98 dakota that did the same thing. If I had to jump the battery, it wouldn't run after charging, unless I had my foot on the pedal, but if I let the truck sit for a while, and than started it, it would be fine.
Old 02-24-2010, 05:42 PM
countywacker's Avatar
countywacker
countywacker is offline
Same thing happend to me a few years ago. I called my friend who was a dodge mechanic and explained it as such. When these trucks batteries go dead and are not started for a while, more or less the computer loses its memory and forgets what do to. So when you jump start the truck you have to keep it going for about 15 to 20mins. Basicly what you are doing in that time is reprograming the truck how to idle by itself and what not.
Old 02-24-2010, 05:46 PM
01greenram's Avatar
01greenram
01greenram is offline
i had the same problem with the iac valve
Old 02-19-2012, 10:38 PM
MangoCats's Avatar
MangoCats
MangoCats is offline
Default 99 5.9 does the same thing
We have a '99 Ram 1500 5.9 with ~140Kmi on it, and it started doing the same thing several months ago - first time was a "hot restart" it wouldn't hold idle, plus the battery was 7 years old, so after 3 or 4 tries, we were on jumper cables getting it to go. Finally hit on the idea to hold the pedal down and it would run (never had to do that before...), after a couple of blocks, didn't have to hold the pedal down any more. After that, replaced battery, but it did the same thing a couple of times, always on a hot restart, starts after sitting overnight were always fine. Took it to the mechanic for a transmission fluid/filter change (first in its life) and it didn't do it there, and we thought it was cured.
A couple of months later, we were on a trip, 150 miles from home, stopped for dinner, and when trying to restart after dinner, same thing, hold down pedal to idle, and had to hold the pedal down through the parking lot, but after getting out of the parking lot, it would idle again. Back to the mechanic again (needed ball joints, serpentine belt, radiator - damn plastic tanks, it is 13 years old after all), and they suggested something about the alternator might address the idle thing, so, new alternator. Just this morning it gave me the "won't idle unless you hold the throttle open" thing on the first start of the morning, after maybe 15 starts without problem.
The longer I live with this idle problem, the more it seems like another perverse PCM issue (we've got a supremely weird issue with the seat belts locking up every 30 minutes while driving, opening a door unlocks them and restarts the 30 minute timer...) The problem seems to go away after rolling, you can sit and idle with your foot on the gas all you want, it never seems to get over the problem while sitting, but as soon as you get tired of that and just put it in gear and lurch away, it's fine after a very short distance, this morning I just rolled forward and back in the driveway, maybe 30 feet, and it was cured.
Runs smooth as silk otherwise...
Old 04-02-2013, 12:23 PM
rott96's Avatar
rott96
rott96 is offline
Been having same issue with my 2000 5.9 .....idle jumps around, idles at around 500 wont hold idle til it warms up....even after warm idles low and iradic....so in essence, if it is the battery...it I hook cables up to my car and the truck then start it it should hold idle???? Just saying before I go and spend $130 for a battery....I'm kinda broke!!!
Old 04-02-2013, 12:26 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,208 Likes on 2,959 Posts
I would start with cleaning the throttle body REALLY well, testing the TPS, and possibly replacing the IAC motor.
Old 04-02-2013, 01:11 PM
mrau92me's Avatar
mrau92me
mrau92me is offline
If it's the IAC valve, the problem may come back. I have a mechanic friend that says these trucks eat up IAC valves. In fact, I ordered one from Adv Auto yesterday that I'm gonna pick up today, because my truck is currently a flip of the coin whether it'll idle after it's been sitting awhile. But, if it's below 45degrees outside, I can almost guarantee that it won't idle upon startup.
Old 04-02-2013, 01:40 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Either way you all go,clean or replace. Remove the negative battery cable first. Here's a DIY for cleaning. https://dodgeforum.com/forum/dodge-r...n-the-iac.html
Quick Reply: Starts But Dies Unless I Give Gas - Won't Idle
