Changing oil sending unit DIY?
Old 06-16-2010, 12:30 AM
DukeSupes's Avatar
DukeSupes
DukeSupes is offline
I still have the intake off. So I will be using....whatever I feel like at the time
Old 06-16-2010, 12:44 AM
notanexit7's Avatar
notanexit7
notanexit7 is offline
I've heard bad things about getting sensors from places like advance auto parts and auto zone so is this something you should get from the stealership? Or what about O'riley's?
Old 06-16-2010, 01:29 AM
M Laborde's Avatar
M Laborde
M Laborde is offline
O'Reilly's is probably where I will get mine. I'll let you know how it works out in a couple of weeks if nobody replies before then.
Old 06-16-2010, 01:37 AM
rumble_truck's Avatar
rumble_truck
rumble_truck is offline
I just went to autozone to get mine, it has a lifetime warranty on it. was something around $20. And i had to use a adjustable wrench to get to it (I didn't have a deep well that was big enough, works fine)
Old 06-16-2010, 01:55 AM
M Laborde's Avatar
M Laborde
Any clearance problems with the wrench?
Old 06-16-2010, 08:26 AM
DukeSupes's Avatar
DukeSupes
I got mine from autozone as well and they do have lifetime warranty. Typically they dont just slap that on just anything.
Old 06-16-2010, 06:08 PM
dodgeman52's Avatar
dodgeman52
dodgeman52 is offline
i got one from advance auto and when i started the truck it shot oil up out of the top. POS i got one from auto zone and have had no problems so far
Old 06-06-2015, 09:00 AM
CGF's Avatar
CGF
CGF is offline
Default '96 Dodge Ram 2500 diesel
Can't even see the oil sending unit. Have to remove several items to get
to it. The preliminary work is tedious unless someone call tell me how to
get it done without all of that. ???
Old 06-06-2015, 10:36 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
Take off the air filter box, lay across the top of the engine, and reach back down behind there. It really isn't that bad.
Old 06-06-2015, 11:33 AM
CPTAFW163's Avatar
CPTAFW163
CPTAFW163 is offline
This might sound like a stupid question, but if I have a small oil leak:
1. Oil glaze on the tranny pan.
2. Oil pressure sometimes dips below 40 then slowly climbs to 60 under acceleration over 2.5K RPM.
3. Coming from the back of the engine.
Could this be the culprit?
Sorry for the thread hijak. I think I found what I will be doing next weekend.
Quick Reply: Changing oil sending unit DIY?
