v10 RAM no start....frustrated
Old 09-30-2011, 05:03 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
And btw, thanks for posting the solution in both threads.
Edit: I've already got the pic downloaded and ready. lol
  #82
Old 09-30-2011, 05:57 PM
ttrash91's Avatar
ttrash91
ttrash91 is offline
CONGRATS!!!
Enjoy it in good health, and stay warm and dry on the way to work.
speaking of that, my heater blower needs attention only works when i kick the bottom of the dash......
and the rf ujoint echoes of buildings going down the strreet
it never ends........lalalala
  #83
Old 09-30-2011, 08:39 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,179 Likes on 2,932 Posts
Will it do that on any speed setting?
Well, the u-joint isn't that bad... check for a zerk fitting first, and grease the snot out of it.
  #84
Old 10-01-2011, 12:38 AM
fargo39's Avatar
fargo39
fargo39 is offline
awsome finding the problem. did you say the trans was rebuilt? wonder if the solinods shorted and melted the plug and thats why the trans was rebuilt. do you charge a higher shop rate for electrical.
  #85
Old 01-01-2015, 06:41 PM
biodoug's Avatar
biodoug
biodoug is offline
New Member
Can any one direct me some place to get a wiring diagram for a 1996 dodge ram 2500 v10 . had it park out in the barn and ground hogs ate the wires
Thanks Doug
  #86
Old 01-01-2015, 07:32 PM
HeyYou is offline
This thread. Download the 96 service manual. Wiring diagrams are in section 8W.
  #87
Old 04-05-2017, 06:16 PM
joetracyjoetracy's Avatar
joetracyjoetracy
joetracyjoetracy is offline
I desperately need help. I have a 1999 Dodge Ram 2500 V10. Motor blew so I bought a replacement from a 1995 Dodge Ram V10. I realize the replacement is OBD1 and it has EGR valve. So I switched Intake Manifolds complete with fuel rails and throttle bodies and passenger side exhaust manifold. I also switched crank sensor and cam sensor. Once complete attempted start. Getting fuel but no fire to plugs. Pulled one plug and verified. Was told that if cam sensor was not installed correctly that damage would occur to sensor which of course would cause the no fire. Then I was told that it was more serious that I now had to remove the front of the engine in order to change something called the firing ring on the front of the camshaft that the 1995 and the 1999 used different rings. Is any of this true? Please please help clarify this for me. My truck has been down for 2-months.
  #88
Old 04-06-2017, 08:42 AM
fargo39's Avatar
fargo39
fargo39 is offline
the cam gear is different between the obd 1 and 2 get a timing chain set for a 99 and it should start did this swap a couple years ago
  #89
Old 06-17-2017, 01:08 AM
Nick Reid's Avatar
Nick Reid
Nick Reid is offline
Default Similar issues, 97 v10
Hey all,
Down to no fuel pressure but have spark. Have voltage at crank and cam sensors, voltage at fuel pump when key is turned but then ASD. Cam sensor is new yesterday. Crank sensor is new 2 years ago. Is this a crank sensor problem to shut down fuel?
  #90
Old 10-17-2022, 01:16 AM
Zachd419's Avatar
Zachd419
Zachd419 is offline
Originally Posted by ttrash91
ok, new to the board here...
been a mechanic over 13 yrs. have some common knowledge of the industry
i have my own shop and can usually figure things out on my own, but i'm going out on a limb here because i'm despereate.
1996 dodge ram 2500 v10 8.0 liter.....
towed in, cranks but no start.
...no spark
... no fuel
replaced ecm with aftermarket part from fisher
truck starts but shuts right off
heard a relay clicking under hood...found later to be TRANS RELAY
(THIS IS WHERE STUFF GETS WEIRD)......
removed relay and truck started and stayed running....test drive
runs good ...stutters every 3-4 seconds, shifts ok
got back to the shop shut off truck and no start again....
reinstalled trans relay.....still no start
installed new crank sensor from dodge....no start
no injector pulse
no spark
fuel pump runs 45psi at rail
battery fully charged
cranks ok
tested 5v to cam and crank sensors, ground good,
HOW DO I TEST SIGNAL FROM CRANK AND CAM
any ideas what to do next?
i've been reading alot of threads and topics.. " hey you" seems to know his s**t.....
TIA.....ttrash
so i just picked up a 94 2500 v10 and im having a crank no spark issue i have two different pcm’s one is the original one is from i dont know where it came with the truck but i had to get ignition coils from a salvage yard and i connected them and i have nothing. The resistance on the coils are good. I havent had a chance to check voltage yet but i have a connector coming off the 4 pack thats a run off from the green and orange wire and i have no idea where it goes to. All interior lights come on the fuel pump primes no problem. I started trying to crank it once i got crank and cam sensors in with starting fluid and i got it so close to starting with that but it died out cuz i ran out of starter fluid so i ran to the gas station and got a few gallons and put it in but i havent been able to get it since. After doing some research ive found a diagram and it says that that green and orange wire is an asd wire could that be why im not getting any spark at all?
on this diagram it looks like the green and orange wires from both coil packs intersect but i have no idea where this little connector goes or if its a ground or not.
Quick Reply: v10 RAM no start....frustrated
