Help with code P1899 before I take it to get fixed.
I got this code about a week ago, went to autozone had it checked and it showed P1899. I replaced the switch right away and the engine light stayed on for a couple of days and went away. It came back throwing the same code. I checked to see if it functions correctly and it wont let me start the car in D or R, also noticed that my back up lights are not working. I tried to follow back the wires but it just went into a huge bundle of wires into the harness. Is there a fuse I can look at? I couldnt find one. Also checked to see if there was any power showing for the lights when in R and it showed nothing. Again while in R and D I checked to see if there was power going to it and it showed nothing....but the Switch works like its suppose to. What am I missing? I also did disconnect the battery a couple of times, the light came back on immideatly.
98, I disconnected it long enough to brush the nipples on the battery. I did it after I installed it. Ill try the oem one. No wires pinched from what I looked at.
Should I disconnect it, install new then hook battery bac up or...?
How long should I leave the battery disconnected?
its always a precaution, ten or fifteen minutes will reset the pcm, ANY time I work on my ram I disconnect the battery. just good habit. I just put new lights on my last weelend if you need a passenger side mine was brand new, I thought the drivers side looked okay until I put a new one on the other side so I bought a whole set. Got a bed cover too if yours is a short box and wanted one.
I did test the switch, it works. No power seems to be going to the switch. Ill unhook the battery to reset it. Also just found out that I couldn't get a solid ground so its probably gettig power which is why the switch works. Could my reverse lights being out cause it to show bad??
The following users liked this post:
Milton Murray (05-03-2020)
