Transmission Pan Sealant Thread
#21
#22
How tight should the bolts feel? I have had a leaky pan gasket (after taking it to the trans shop that said it had a bend in the pan that they fixed). I was under the truck today and decided to check the bolts. They felt very loose to me but then again I didnt use a torque wrench either. I snugged them down but I didn't overly tighten them and fluid leaked out from under the bolt heads. I hope I didn't get them to tight
#23
#25
after struggling with cork - i may migrate to this with a rubber gasket
http://www.permatex.com/products-2/p...ressing-detail
The cork gasket the trans shop installed is leaking
