Transmission Cooler Line Leaking
Old 01-08-2014, 11:41 PM
jamesnb's Avatar
jamesnb
jamesnb is offline
Default Transmission Cooler Line Leaking
I have a '01 1500 Ram 4x4 with a factory installed transmission cooler (part of the towing package). The cooler is located between the radiator and the AC condenser. I was doing some work on the truck last week and I must have damaged the aluminum line where it makes the turn to go back into the engine bay because it's leaking.
Is there a reliable way to fix the leak or should I just replace the cooler? I was thinking I could cut the aluminum tubing and install a compression fitting or flare the end and attach a hose and clamp. I don't trust just sliding hose over the leak without some sort of barb.
If replacing the cooler is the way to go, does anybody have any helpful hints? It doesn't seem like too big a job.
Old 01-09-2014, 09:29 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
If you have enough line, I think flaring it, and installing a barb would be the best bet. No real need to replace the entire cooler.
Either that, or you might be able to go to a radiator shop, and have it soldered up.... Not sure what that would cost.
Old 01-09-2014, 06:47 PM
kejobe's Avatar
kejobe
kejobe is offline
This. Just be sure to use hose rated for tranny fluid.
Old 01-09-2014, 10:08 PM
jamesnb's Avatar
jamesnb
jamesnb is offline
There's probably two feet of aluminum tubing between the leak and the cooler. I'll give that a try. Thanks.
Quick Reply: Transmission Cooler Line Leaking
