Twin turbo Ram(360)
#21
The M1 on the other hand, IS a direct swap. Everything just bolts right up. Minor sticking point is.... need to drill and tap a hole for the IAT sensor.
#22
#25
Hughes.
M1 <- These have gotten REALLY expensive of late for some reason...... Holy smokes.
The kegger manifold will NOT tolerate boost. It's a two-piece design, and the seal is designed for vacuum, not pressure. It won't last five minutes under boost. Could weld it I suppose. That would certainly be cheaper.
#27
Hughes.
#29
