Block test passed still burning coolant
You can check the plenum with a dentist mirror, take the air hat off, open TB and have a peak with the mirror. Look for pooling oil. Spray pattern near PCV is normal.
I doubt an intake gasket leak would get coolant into the combustion chamber. Passages are good distance from intake ports.....
If it is burning coolant, you either have a blown headgasket, or cracked head. Worst case would be cracks in the cylinder wall, but, you would have had to seriously overheat the engine to manage that......
In any event, heads are going to need to come off. Personally, I wouldn't even bother taking them to the machine shop. Just replace them. You can pick up a pair of NEW, better casting heads, for around 600 bucks.
Yep. From Odessa/Clearwater Cylinder head in Florida.
http://www.ebay.com/itm/NEW-FITS-DODGE-JEEP-MAGNUM-5-2-5-9-318-360-CYLINDER-HEADS-/171027563637?pt=Motors_Car_Truck_Parts_Accessories&hash=item27d2098475&vxp=mtr
Titan Engines also has them on ebay, for 560 for a pair. Also with free shipping. Not familiar with them though.
They say to put oil in the cylinders to check for worn rings. The truck doesnt burn oil. Just alot of coolant. I know this truck has a serious problem.
