Warm Up Smoke
He's talking about the Intake Manifold gaskets. Get Felpro ones for that. They actually sell an intake gasket kit. You could just grab that.
Here's what I used when I did my timing chain: http://www.pavementsucks.com/tech-article-37.html
You'll be replacing the Timing Chain (with a double roller chain), the Camshaft Sprocket and the Crankshaft Sprocket. You're current chain probably has a lot of slack in it, and a new chain takes that slack out. That slack messes with the timing and if the chain is bad enough, your truck can jump time.
I would recommend having a 3-jaw puller handy when you do your timing chain. My crankshaft sprocket wouldn't come off and I had to use a puller. Call a local parts store and see if they will rent you a 3-jaw puller and a harmonic balancer puller.
I guess the problem right now is that I don't know where all of these parts are located on the truck, or how to tell if they need to be replaced. I'll take a look at my haynes manual and my truck and figure it out.
To replace the chain, I assume I can't just put the chain anywhere on the sprockets. I don't understand what I was reading about adding +4 to get more low-end torque. How do I know I'm aligning the chain on the sprockets correctly and I don't completely screw up the timing on my truck?
Your timing chain set will come with the gears. Don't need to worry about that.
To replace you do this.
Take old chain and sprockets off. DO NOT MOVE ANYTHING. then simply put the new sprockets and chain on. done.
Will need a timing cover gasket
How old is your water pump? You will have to take it off. if it's old might be wise to replace it if funds allow while everything is broken down.
This is not a week long job. Just a week end job.
It sounds confusing at first, but going into it head first is how I learn. Taking stuff apart and now I know where everything is and how it works.
Water pump hose from intake to the pump is a good thing to replace.
How old are your plugs and wires? Dizzy cap and rotor? A lot easier to replace with the intake off. But not neccessary.
I might have some pictures I post up Idk I thought I lost them
Ok, i've looked a couple different places for the timing chain / sprocket set for sale. I can't find it. Does anyone have a link to a good one?
I've asked 2 different long-time members if they knew where I could find a link to a service manual for my truck (1999 1500 2wd 5.2L) and neither ever responded. The link in the DIY sticky from JasonW doesn't work anymore. Does anyone know where I can get the PDF so I can save it to my pc?
Service manual thread. Link for 98-99 works just fine for me. Save it to your local machine. Loads faster that way.
Thanks Hey You. That's what I am trying to do. The 1998-1999 link sends me to this page (http://spillage.net/Public/98%20Dodg...Truck%20SM.pdf) which then states "This Webpage Is Not Available."
Does anyone else get that? Is it just my pc? I can download the 1996-1997 manual fine, but not the 1998-1999.
