Strange Idle Issue... Even For My Truck :)
The fact I didn't get the code on my scanner concerns me as well. However, it had been two days since I last hooked up to it, so I suppose it is possible it through a code during that time.
I did check voltage at connectors, and did have voltage two powers two grounds. The readings were spiking at 13/14v though, and they were constantly changing polarity the entire time.
So for the conclusion to this thread...
Picked my truck up from the mechanic Friday night. I made the decision I would try messing with it some more before buying a new computer and installing it.
I went and bought a new IAC...cheapest one I could find was a masterpro from oreilly's for $27. I wasn't going to go drop another $100 at the dealership for one like I had just done last year.
I checked continuity from the iac connector to the plug on the computer, and all checked out okay. I pulled the connector from the computer and clean the pcm and connector with some electronic cleaner and compressed air. I also bent down a small tab on the connector to the IAC, just to make sure it was making contact with the iac pins. Stuck the new iac in, and she fired right up.
I'm tempted to go install one of the other two iac valves in to see if the problem comes back, just to see if cleaning the computer and connectors fixed it, or if I had two bad iac's, but it's been really cold here, and I'm just happy it's working again. If I had to guess, I think it probably was yet another bad iac valve.
We'll see how long this $27 masterpro lasts. If it makes it longer then 18 month's it will have beaten out the dealership crap from dodge, and at a third of the cost. end rant
Thanks for everyone's input on this. It helped out a lot.
