Keyless Entry ?.
Keyless Entry ?.
My truck doesn`t have keyless entry, but I would like to add it if possible. I know you can buy an after market kit and have it installed, but I would like to know how the factory keyless entry works in these trucks. Is the factory keyless entry a module or something that plugs in under the dash some were that makes the keyless entry work or ? If it is a module or something like that, that I could find at a junk yard I would like to do that if possible and then have a key programed for it.
Any information on this would be a great help.
I just checked the build sheet for my truck, I can`t find any mention of the highline central timer module (CMT). I did find an old thread here from 2009 that said there were two types of central timer modules, the standard module and the highline module.
So i`m guessing my truck has the standard central timer module. I will have to see if I can find a highline central timer module at a junk yard.
you can add that as well.. there are actually 3 ctms standard or basic, high-line, and premium. basically only difference is the premium has function for the heated seats (only quad cab) for key-less you have to have at minimum the high line and harness and remotes the harness must be ran through the a pillar and plugs into the fuse panel on dash
