35inch tires fit?
What size spacers on the front? The 3/4 ton trucks sit a bit higher than their half-ton brethren in any event, so, if you have two inches or better, they *should* fit, for a street driven truck...... If you off-road, and do any flexing, you will probably find they rub. (and in any event, the may rub at full lock anyway.)
Ok thanks for your input guys. I think the spacer is an inch. She still has a small front squat. I just bought this 98.5 cummins and I'm going to put a bigger wheel setup on it she looks too low to the ground. My new wheels will have some offset. Might go with 33s just to be safe.
On a side note. I have a 99 1500 as well. 33" tires do rub at full lock, but its also a half ton and the tires are 12.5" wide. But they do have some offset.
