sucessful 46rh conversion- just need tweaking
I was.... yesterday when it was shifting into OD. Today it would not. After driving it around yesterday with no problem I didn't touch anything so I know nothing changed. I don't understand why the OD conversion stopped working. maybe I will try a new piece of vacuum hose, find a harder hose and bring it in a few more inches.
3rd gear still hides when cold but after a trip on the interstate she shifts into 3 easier. Not sure what is going on there either.
Vacuum and 2 pressure switches. I adjusted the vacuum Down to 2lbs yesterday and it worked perfect. Not sure why it wouldnt work today. I changed the vacuum hose going to it by no luck. I know I have power going to the switch. I am just lost on this one.
I adjusted tv cable again and this afternoon it was working good but will have to check when it is cold again. I will not be driving it to work again until I know the OD works right
I think the no 3rd and od is two different issues. I would lock out the overdrive from engaging and get 3rd working first. Since the A518/500 is a 727 with od go by the trouble shooting guide for no 3rd. Usually band/tv cable out of adjustment. Witch pressue switch did you get for the od? Seem they have a few(44-54 psi). After getting 3 worked out i would see if you are getting the psi to triger the switch.
I am beginning to think it is a governor pressure problem. The OD switches are connected to the governor pressure and I bet the governor has something to do with 3rd gear.
The other day when it went to shift to 3rd but there was nothing there, I couldn't even get it to go back into 2nd, I had to manual rip the handle down to 2nd and get it up to about 55, shift back into D and let off the gas. I had to do this 3 times before it would finally catch 3rd gear. after that it would shift into 3rd gear but never consistent. Some times at 32 mph and other times not until I hit 50-55 mph with the same driving habits. I wonder if the transmission had other problems that the rebuilder didn't question but should have. So frustrating, I have so much time and money in this swap and I cannot get it to work right.
Well, I ended up taking it back to another transmission shop to have it checked out and decided just to have it rebuild by a real tranny shop. Found the clutch plates were excessively worn and debris in the valve body. Now she runs and drives perfect! The PATC kit works like a charm and hits on time every time. The only think now is possibly changing the gear ratio. 1900 RPM at 80 just seems a little low and I really feel like I am using more gas to keep it between 75-80 then if I had a better rear gear. That and OD don't kick in until about 53mph and lock up is after 56/57 mph so on local streets I am still in 3rd gear in higher RPM. I am running the stock 3.2 gears now so I have to decide what to switch over to. Thinking about the 3.55 but not sold on anything yet.
