Auto Transmission Problem
I adjusted the external linkage on the transmission on my 94 Dodge that has the over drive tansmission and is driven by a 318 motor. At first it would go into park kind of hard and started not to engage at all and now is in reverse when I park it. I replaced all of the busing, checked the adjustment and took the rod off of the side of the transmission lever and it is in it furthest limit to catch park and put the rod back inn. My question is there an adjustment inside the case that has loosened or do I have something bent in there that Will not engage the parking paw.
Thanks
Emmett
Thanks
Emmett
