Coolant leak
Old 09-04-2015, 11:18 PM
zramsst's Avatar
zramsst
zramsst is offline
Default Coolant leak
I noticed a coolant leak at the water pump. I checked around the pulley and it's dry. Where is the weep hole? I'm pretty sure it is coming from the heater hose pipe that goes into the water pump. I noticed the o ring is on the pipe but it isn't in the hole, Its on top of the water pump, I'm assuming it fits in the hole?
Old 09-05-2015, 12:13 AM
beeker's Avatar
beeker
beeker is offline
The oring indeed should be inside the pump. Remove pipe and install new oring with some oil.
Old 09-05-2015, 04:18 AM
HeikIlm's Avatar
HeikIlm
HeikIlm is offline
And check the condition of the pipe. I've heard that they are prone to rust.
Old 09-05-2015, 08:28 AM
Moparite's Avatar
Moparite
Moparite is offline
The pipe has a grove where the o ring sits, There is a bracket that supports it from moving so it may not be in all the way.
Old 09-05-2015, 08:53 AM
Khris1994's Avatar
Khris1994
Khris1994 is offline
It's a cheap buy from summit of its in bad shape. I just bought a new one for my plenum repair
Old 09-05-2015, 10:12 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,179 Likes on 2,932 Posts
Local parts stores should have them as well, in the "Help" section. Runs about 15 bucks I think. (seems a lot for what it is.....)
Old 09-05-2015, 10:30 AM
Khris1994's Avatar
Khris1994
coolant tube here
But the downfall is you pay shipping. I ordered a couple things so it was worth it for me to order the tube from them
Quick Reply: Coolant leak
