Replaced everything in the circuit still problems
Hey guys,
Now the truck is dead won't even start but turns over. No codes anymore just "pdone".I pulled the plug on the wiring going to the cam positioning sensor and checked voltage. I am obviously not real good at this computer stuff and intermittent shorts but I am trying. If you look at the plug with the long side up (like an upside down bell with the yellow in top center?) Top row L-R 5.15, .02, 5.14, bottom row 5.15, .02, 5.14.
I am slow at this because I am disabled, not whining just in case your wondering why this is taking so longer. Hard for me to get into some of these positions but I am learning at least. Should I plug it back in and test at every sensor? So frustrating especially since I used to be a good mechanic just not in this area.
also fuel pressure at the rail is about 50# so that's not an issue.
Received Noid lights today and the plastic on the injectors was so brittle I was only able to check three but they all flashed once to indicate that they are getting a signal. The vehicle won't start so no way to check it while running. I also picked up a Relay tool that checks all of the relays one by one and they are all good. Took dist cap off today and checked the inside of distributor to make sure all was in order and it was. Now it's throwing a P0340 code again and won't start even while on a 40 amp charger in start mode. I'm not sure which pins or which plug on the PCM to pull and check for voltage. This is the longest I've ever had any of my vehicles down and I still haven't found the problem. I'm about ready to put a FORD sticker on the side of the truck! Just ordered a Mopar Camshaft position sensor, it will be here on Wednesday. I just can't imagine it being the answer but It was suggested and at that point everything has been replaced some things twice. This is driving me crazy.
