Wet floor when it rains
Old 12-07-2015, 01:34 PM
BigGreenRam's Avatar
BigGreenRam
BigGreenRam is offline
Seal the rear window at the rubber and body all the way around and pull the 3rd brake light light coat on it I used black ultra I don't have anymore water in my truck. Rear Windows are known to leak in these trucks
Old 12-07-2015, 02:59 PM
hdbiker1's Avatar
hdbiker1
hdbiker1 is offline
I'll have to check that, but the carpet isn't wet anywhere except where the passengers feet are. I would think that you'd be able to feel wetness behind the seat, but I could be wrong.
Old 12-07-2015, 03:26 PM
BigGreenRam
Nope u won't it runs down a channel mine did the same thing
Old 12-08-2015, 07:44 AM
eggyjla's Avatar
eggyjla
eggyjla is offline
Floor mainly under the driver-side, but a little on the passenger side. Always got sopping wet after a good rain. I ended up pulling the entire carpet out to dry TWICE. In the end the seal around the third brake light was the problem.
Old 12-08-2015, 09:07 AM
brewman's Avatar
brewman
brewman is offline
I have a 97 extended cab that was letting rain in. Turns out it was the sliding window in the back window. I replaced the entire back window with a single piece of glass, and no problems since.
Old 12-08-2015, 03:31 PM
BigGreenRam
There u go
Old 12-08-2015, 04:27 PM
hdbiker1's Avatar
hdbiker1
hdbiker1 is offline
All good info. Thanks guys.
Old 02-03-2016, 08:03 PM
hdbiker1's Avatar
hdbiker1
hdbiker1 is offline
Update. Finally got frustrated with all this rain and sent it to a shop. They found it. Someone had installed aftermarket speakers in the doors and the routing of the wires pushed the vapor seal open at the bottom.
Old 02-03-2016, 09:37 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,205 Likes on 2,957 Posts
Vapor seal? On the INSIDE of the doors? If you are getting enough water inside the door, that it comes out from the vapor seal, into the cab, something else is going on there......
Old 02-04-2016, 01:00 AM
hdbiker1's Avatar
hdbiker1
hdbiker1 is offline
The way it was explained to me was, the wires pushed on the vapor seal at the bottom and broke the seal thereby letting rain water run down the loop, through the opening, down to the door seal, onto the door sill and onto the carpet.
I asked them if they checked other places since I was kinda skeptical and was told yes. I asked if they guarantee no other leaks. They said yes, so we'll see.
Quick Reply: Wet floor when it rains
