Throttle Sticking?
Throttle Sticking?
I push the gas pedal, and I BARELY touch the gas pedal, the RPM'S jump way up, but takes it sweeeeeet time coming back down to idle. But, it only does it in "P" (park). When idling, the RPM's fluctuate (I'd say about 200-400 rpms, which is a guess, because I don't have a tach). Any ideas? Already tested the throttle position sensor and the Idle Air Control Valve, and cleaned the throttle body. Also, only i
