46re transmission question
So I'm throwing a code for the torque converter clutch solenoid I found a kit that comes with everything shown in the picture but all the guys at orileys say replacing the tccs will only be a temp fix and what the truck really needs it a new torque converter and I'd rather get more opinions on this
Also if I do replace the torque converter and recommended one to use and would it be easier to pull the motor or drop the tranny to do it
No the solenoid is a common failure. That kit is a good set but you'll have to drop the valve body to install it. Not too difficult but just a heads up. It's easier to install all the parts anyways with the valve body off.
I rarely find someone behind the parts counter that knows much about anything vehicles unless you happen to find an old timer that has been doing nothing since he was young.
