Grinding Noise When Trying To Shift Into 4L
Old 07-17-2006, 10:51 PM
viper187's Avatar
viper187
viper187 is offline
Default RE: Grinding Noise When Trying To Shift Into 4L
Yeah I try to as often as I can but I don't live in an area with very many offroading spots. And I assume that it's bad to run 4x4 on pavement. Is it ok to test it on a gravel road or something?
Old 07-17-2006, 11:52 PM
The Burning Rom's Avatar
The Burning Rom
The Burning Rom is offline
ORIGINAL: viper187
Gravel roads are fine. If you have a grassy area you can drive on, that would work too. You don't have to put it in 4wd and wheel it every month. Just let the system engage and drive 50ft or so. Then put it in 4lo and go another 50 (or back up first and do the same 50 again). Then take it out.
Old 07-18-2006, 12:42 AM
Chopper1's Avatar
Chopper1
Chopper1 is offline
You can put it in and run 4WD on pavement as long as you are driving slow and don't make any turns. After changing my gears I would run in 4WD for the short trip down my street to the main road for a week or so, to break the front gears in. Just don't turn!!!
Quick Reply: Grinding Noise When Trying To Shift Into 4L
