AC cuts out on acceleration
RE: AC cuts out on acceleration
Is it really switching vents? The only time it's vacuum related is when it switches vents.
Try backing off on the throttle. Most AC systems cut out at WOT (wide open throttle). There's even a relay for it.
Most performance PCMs are modified to cut the AC out even sooner when going to WOT.
ORIGINAL: dualstr8pipes
Same thing is happening to me can someone describe how to fix it or post a link or something please.
OK, sorry to hi-jack but what is happening when the AC switches vents?
I went out of town last weekend and during a bumpy section of road the AC would switch from the front vents to the heater/defroster vents. It would stay that way for a while, then switch back. This happened about 5 times over the weekend.
Any ideas?
Any ideas?
ORIGINAL: xjcrawlr
Check first to see if this service bulliten applies to you: http://dodgeram.info/tsb/1996/24-01-96a.htm
Trending Topics
