Sound when you lock truck.
Old 05-11-2009, 08:03 PM
ap0091's Avatar
ap0091
ap0091 is offline
Default Sound when you lock truck.
is it possible to change the sound when you lock your truck?? the chrip.
Old 05-11-2009, 09:25 PM
superdak05's Avatar
superdak05
superdak05 is offline
i think only the aftermarket ones can do that, ours is just the horn beep
Old 05-11-2009, 09:28 PM
LB's Avatar
LB
LB is offline
You can silence it, but I don't think you can change it.
LB
Old 05-11-2009, 09:50 PM
canadiandodge's Avatar
canadiandodge
canadiandodge is offline
how can i slience it
Old 05-11-2009, 10:18 PM
dakota_raven's Avatar
dakota_raven
dakota_raven is offline
To disable the horn chirp this is what you need to do:
1) Press and hold the LOCK button on your transmitter
2) After holding the LOCK button for four seconds, also
press the PANIC button within six seconds
3) You will hear a single chime indicating you of the change in the settings.
Hope it helps!!
Quick Reply: Sound when you lock truck.
