Feeling every bump in the road in steering wheel.
Old 02-18-2012, 05:57 PM
daterxies's Avatar
daterxies
daterxies is offline
Default Feeling every bump in the road in steering wheel.
Well i finally got my front drive shaft replaced, 4wd kicks in and rides nice and not noisy now to bad Wisconsin aint seeing snow, id like to use it at least once this year now that its fixed
So now that that is off my list, anyone have any suggestions on what can cause me to feel every single bump in the steering wheel? When i bought it it was not like this, its something that's developed mostly in the past year mainly.
Last year i had my swaybar links and stuff fixed because over bumps i kept hearing clunking, clunking now non-existent, but now i feel bumps thru the wheel all the time, and not lightly either.
thanks.
Old 02-18-2012, 06:17 PM
Alfons's Avatar
Alfons
Alfons is offline
thanks.
Have you checked the struts and all the steering joints?
What did you end up doing for a drive shaft?
Old 02-19-2012, 01:45 AM
Eimer123's Avatar
Eimer123
Eimer123 is offline
Could be a number of things, tie rod ends, tie rod inners, wheel bearings, strut mounts, internal pressure valves in the rack have failed, intermediate shaft.
Old 02-19-2012, 01:47 AM
hendrixx324's Avatar
hendrixx324
hendrixx324 is offline
does your steering wheel trying jerking out of your hand?
Old 02-19-2012, 10:35 AM
varnerhba's Avatar
varnerhba
varnerhba is offline
thanks.
KEY QUESTION: how many miles/what year
Old 02-20-2012, 08:47 AM
daterxies's Avatar
daterxies
The wheel doesn't jerk, you can just feel all vibrations through it. It's a 05 and just rolled 90k miles
Old 02-20-2012, 10:32 AM
jkeaton is offline
Dodge Forum Administrator
Mine was doing that and it was one of the tie rod ends I buggered up when installing my leveling kit. Lesson learned. Dont use a pickle fork if you want to re-use a tie rod end (or a ball joint). Replaced the tie rods and it went away.
Quick Reply: Feeling every bump in the road in steering wheel.
