AUX gauge pillar
Old Aug 9, 2011 | 12:34 PM
littleBIGdodge's Avatar
littleBIGdodge
Default AUX gauge pillar
I havent been able to find a AUX pillar gauge set up anywhere for sale? Do they even make them for 2006 dakotas? I would prefer the pillar gauge set up (like of the full size rams) mount over the, dash and underdash pods. I wanted to install a tranny temp gauge, oil pressure, and maybe a battery gauge.
Old Aug 9, 2011 | 01:07 PM
HammerZ71's Avatar
HammerZ71
You know you just might be right, I checked where I got mine for my Ram and they only had them for '97-'04 Daks, so I did a quick search at the three truck accessory shops I normally go to for stuff and all three had them - but just for '97-'04 Daks also...
Old Aug 9, 2011 | 01:10 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
There are none for our trucks. Some of the members have fabbed up a couple with some fiber glass on the existing pillar... you are out of luck. They do however have some for the steering wheel column like you said you didnt want though...
Old Aug 9, 2011 | 03:31 PM
MitsuRaider's Avatar
MitsuRaider
Autometer makes one!
Im using it on my set-up
Old Aug 10, 2011 | 01:05 PM
QuadDodge02's Avatar
QuadDodge02
what is the part number on the guage pod? i cant find it anywhere, i want to put my air spring pressure guage in it
Old Aug 10, 2011 | 02:45 PM
Altair's Avatar
Altair
Dak attack!
I believe some people have modified pillar pods intended for the 3g Rams but there is none that I know of specifically for our trucks.
Old Aug 10, 2011 | 03:56 PM
MitsuRaider
Auto Meter ATM-15014
I got off of summit racing.
Its described as fitting only the 03-08 rams but it will work in your truck with no modifications.
Old Aug 10, 2011 | 04:03 PM
dodgetrucker75's Avatar
dodgetrucker75
yup thats what i run too, i also modded one from a 98-02 ram that fits awsome for the a-pillar
Old Aug 10, 2011 | 05:26 PM
moparmaniac1999's Avatar
moparmaniac1999
What did you have to do to make it fit the pillar?
Old Aug 10, 2011 | 06:03 PM
dodgetrucker75
just trim the ends and drill a hole and install a longer bolt into the original pillar bolt hole
here r the trim pics, top is what i started with, the bottom 2 is what installed
