Doing a fluid change and need bolt torque specs
Old 07-16-2015, 08:07 AM
mTn_biKer65's Avatar
mTn_biKer65
mTn_biKer65 is offline
Default Doing a fluid change and need bolt torque specs
I'm doing a fluid change on my 2008 Dodge Dakota SLT 4x4 with a 4.7 and the only thing I'm not sure about is the torque spec for the following bolts.
Rear differential pan bolts
Front differential pan bolts
Transmissions pan bolts
Transfer case drain & fill bolts
One last question. I'll be putting 75w140 in the rear differential but I've read the following "If equipped with Trac-lok add 0.25 pints (118mL) of Limited Slip Additive.". How do I determine if my truck has Trac-lok? I've read to look at the sticker in the glove box but my truck doesn't have a sticker there. I do have the spec sheet for the truck in front of me. Would it be on there somewhere?
Thanks
Paul
Old 07-16-2015, 02:07 PM
dakotaff's Avatar
dakotaff
dakotaff is offline
Follow the link below my signature pic. There you can get your build sheet to see what's in the rear, and the 2005 FSM may have all of those torque specs inside.
Quick Reply: Doing a fluid change and need bolt torque specs
