Front propeller shaft (drive-shaft)
Old 05-04-2016, 06:14 PM
donkeypunch's Avatar
donkeypunch
donkeypunch is offline
King Jackass
Default Front propeller shaft (drive-shaft)
So I've finally crossed the 200K mark and have had the first drivetrain failure: the cv joint in the front propeller shaft has failed. At first, I almost pooped my drawers when I suspected a t-case failure, based on the symptoms. Thank goodness its only the shaft. So, in researching, I found a cost effective solution...that fixes the factory f*ck up: http://www.proshaftllc.com/collectio...mission-trucks
For most of ya'll, we would need to verify length for the automatic pickups. As I understand it, they can make this in any length. Aaaaaaand, it's cheaper...and stronger.....so....I bought it. I will keep the thread going for pictures, install, review, etc.
Until then, here is some gratuitous gun ****:
File Type: jpg
Old 05-19-2016, 05:47 PM
jkeaton is offline
Dodge Forum Administrator
So......where's the pics? (Besides the gun ****)
Old 05-20-2016, 02:04 PM
donkeypunch
King Jackass
Well, I received it, but it was too short. So I had to wait for the correct length to arrive. Apparently there is conflicting lengths for a manual trans Dakota prop shaft. Lol. Here is a photo of the shorty. More photos to come in the next couple hours...stand by...
File Type: jpg
Old 05-20-2016, 02:07 PM
donkeypunch
King Jackass
More **** for you boom-stick operators out there...
File Type: jpg
Old 05-20-2016, 06:45 PM
donkeypunch
King Jackass
Here's a photo of the front prop shaft installed. Its legit: no vibration, comes pre-balanced. Pro-shaft FTW!
File Type: jpg
File Type: jpg
Quick Reply: Front propeller shaft (drive-shaft)
