3rd Gen Durango 2011+ models
Is l Fuel pump relay recall P54 the same as Fuel pump relay recall P09?
Old 09-28-2016, 01:02 PM
danix4u's Avatar
danix4u
danix4u is offline
Exclamation Is l Fuel pump relay recall P54 the same as Fuel pump relay recall P09?
I have took my Durnago 2013 last year to fix the recall P09 and they did it. I went recently to another dealer and they said it is still not done! I checked last year work order and I found that they did recall fix P54 on my 2013 Durango. P54 is for Dodge Durango 2011 and it is for Fuel pump relay issue the same as the P09.
Does that mean I have to do the P09 again or both recall fixes are exactly the same and it should not be done again?
Are the parts and the work to be done exactly the same for P54 and P09?
Old 09-28-2016, 01:17 PM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
Hi danix4u--if you check https://www.mopar.com/en-us/my-vehicle/recalls.html, you can see which recalls have been completed and which ones are open on your vehicle. The correct recall needs to be completed for your vehicle.
Kori
Dodge Social Care Specialist
Quick Reply: Is l Fuel pump relay recall P54 the same as Fuel pump relay recall P09?
