help replacing speaker on driver and passanger side doors?
and if its a 06+ ram there is 2 phillips head screws on bottom of door. one up near where the mirror is ( but on the inside obviously) one torx bit in the handle ( have to take handle off) then youll see the last phillips head behind handle. lift up over door lock rod and then pull out ( be carefull not to pull to hard as the wires to the doorlock/window up/down switch are short.
