flashing check engine light and lighting bolt
Old 06-01-2010, 03:15 PM
hoss67's Avatar
hoss67
hoss67 is offline
Originally Posted by weedahoe
There is a reason this thread is dead. You DO realize it is over 2 yrs old right?
i was like who are these members, never seen them before and they had mass posts lol now i know why
Old 05-25-2019, 02:29 PM
Taylor86's Avatar
Taylor86
Taylor86 is offline
Default Lightning bolt fix
Mine did it a few months ago would spin over buy not crank, cleaned the electronic throttle control module and ran fine, then yesterday did something similar would spin over for a few then crank but ran rough and couldn’t give it any gas, so bought new electronic throttle control module, didn’t fix it, was the oil sensor unit, easier way to check that is to unplug it and if it starts and runs fine then that’s your problem.
Originally Posted by pottsy87
that light came on for me as well, i used the key on off trick.
got P2175(throttle actuator control sys - low airflow detected)and
P2106(throttle actuator control sys - forced limited power)
i found what the codes meant by doing a google search and came across this site www.obd-codes.com search their forums and you should be able to find somethin.
Quick Reply: flashing check engine light and lighting bolt
