check engine light after cold air in take install
Old 03-14-2009, 12:08 AM
pcollins's Avatar
pcollins
pcollins is offline
Originally Posted by chambers
I wonder why some people get CEL's when they install CAI's and others don't. You would think going from stock to a lot more air flow we would all get them. My truck idled funny for a little bit until it got used to the extra air but not CEL.
When I installed my Airaid I got a CEL, but it was because I hadnt disconnected the battery. Once I did a disconnect/reconnect it went away.
Old 03-14-2009, 08:07 AM
bdhuntr's Avatar
bdhuntr
bdhuntr is offline
Just pull the PCM fuse. Why disconnect the battery and lose your radio presets, etc why all you have to do is pull one fuse?
Old 04-01-2009, 08:54 AM
GETRAMMD's Avatar
GETRAMMD
GETRAMMD is offline
Okay, new to this one, so how do you know which fuse it is?
Old 04-01-2009, 10:37 AM
RubberFrog's Avatar
RubberFrog
RubberFrog is offline
Don't bother. It will go away on it's own once the pcm learns the new air flow. Give it a day or so and you'll be fine.
Old 01-21-2017, 11:03 PM
simpleasy's Avatar
simpleasy
simpleasy is offline
Question no workee
2000 ram, 5.2 no mods
Just installed Cold air intake, 10 miles.....CEL.Disconnected batt. for an hour, light was gone, for another few miles now back.
Running fine.............??????????
Old 01-22-2017, 09:04 AM
superdak05's Avatar
superdak05
superdak05 is offline
what your suppose to do after install, start and stop truck 3 times, after the third time leave truck running for a few minutes to relearn. then take truck for a ride and make sure all is well.
Old 01-22-2017, 04:34 PM
simpleasy's Avatar
simpleasy
Should I disconnect to clear light first or just the 3 cycle start??
Old 01-26-2017, 12:00 PM
superdak05's Avatar
superdak05
light should go off after driving
Old 01-26-2017, 08:51 PM
simpleasy's Avatar
simpleasy
YES!! on this morning to work, and not on the way home,,,,awsome!!
Quick Reply: check engine light after cold air in take install
