Evap code question
#21
#22
I have a 2003 ram 4x4 hemi. Had p0441 come up. Looked around Evap canister and one of the hoses was cracked and half slipped off the nipple. I replaced all 4 hoses and all the fittings, and the gas cap. A week later the CEL came back on with the same p0441 code. Should I replace the purge solenoid? It would be cheaper than the 135 for the dealer smoke test. The purge solenoid is the thing in the engine bay behind the drivers side headlight right?
Any help would be great.
#23
no pwer to no power to EVAP purge solenoid
04 dodge ram 2500 hemi magnum 5.7 4x4 I had a code read on my truck when the engine light came on it said to change the EVAP purge solenoid so I did now the engine light is still on but when checked again no codes come up but light is still on says 0 codes read please help
No Power To EVAP purge solenoid !!!!!
#24
[QUOTE=sandraed1963;3250781]04 dodge ram 2500 hemi magnum 5.7 4x4 I had a code read on my truck when the engine light came on it said to change the EVAP purge solenoid so I did now the engine light is still on but when checked again no codes come up but light is still on says 0 codes read please help
No cracked hoses everything good truck still runs great just light still on
