Evap code question
Old Apr 21, 2009 | 02:02 PM
MontanaRAM's Avatar
MontanaRAM
Default Evap code question
i have 2 codes coming up on my tac and i would like to find out what they are in laments terms. i have code P-0440 (Evap sys Perf) and P-0456 (Evap leak monitor small) what are these and where are they located? can i fix them myself?
Old Apr 21, 2009 | 02:44 PM
02Steve1990's Avatar
02Steve1990
check for any bad hoses near the ps pump to see if there are any problems there, if nothing then check your gas cap, i had an evap code on my dash last week and i switched gas caps with my friend who owns another ram and the code never came back on once i had it reset at advanced
Old May 21, 2009 | 03:45 AM
khooper's Avatar
khooper
A code P0440 could mean one or more of the following has happened: The gas cap is not installed or working properly. The purge solenoid has failed. The canister is plugged and not working properly.
P0456- small evap leak detected related to the P0441 which is in most cases the result of debris in the Evaporative Emission Control System.
Tips: Be careful in choosing parts to use, so that you'll be satisfied just like in my gmc oem parts
Old Sep 19, 2009 | 12:26 PM
SilverRam2004's Avatar
SilverRam2004
I have the Code P0441for the EVAP canister purge solenoid. How do I replace this and if I prolong replacement am I doing further damage to my engine? ANy help will be much appreciated.
Old Sep 19, 2009 | 06:26 PM
MontanaRAM's Avatar
MontanaRAM
i still haven't done anything with mine and the truck runs fine, so i wouldn't be too concerned about it.
Old Nov 8, 2010 | 01:55 AM
kobebrown7's Avatar
kobebrown7
Ya I have a 2003 dodge ram 2500 hemi and the code P0440 has came up so i went and bought a new gas cap and 5 days later is came back on showin the same code? so what I have a bad purge solenoid or canister?? is those easy to fix yourself? where are they located at under the hood? Thanks
Old Nov 8, 2010 | 01:27 PM
Greg in MO's Avatar
Greg in MO
You most likely have a crack in one of the hoses connected to the EVAP cannister (see attachment #10).
Yes, it is easy to fix yourself. You might need an inspection mirror to see the tops of the hoses , but check them carefully for splits and cracks. If they are cracked, just replace them. If you can't find any cracks, try replacing your gas cap, as the gasket may be bad.
Good luck!
Greg
Old Nov 8, 2010 | 01:29 PM
MongoDV8's Avatar
MongoDV8
Check for dry rotted / split hoses on the pump located under neath the truck near the gas tank. I replaced 2 hoses on my 2003 2500 amd 2 hoses on my wifes 2001 durango.
Old Nov 8, 2010 | 06:42 PM
HemiRam1566's Avatar
HemiRam1566
had that code come up on my truck the evap canister was cracked
Old Nov 9, 2010 | 05:59 PM
kobebrown7's Avatar
kobebrown7
Unhappy
So I looked at the hoses they are the stock old ones but dont seem to have any cracks on them and the canister looks good?? but sometimes when I get out of my truck I smell fuel?? so there has to be a leak right under there somewhere but cant find it? could they purge solenoid or canister be plugged? I called the stealer and they said they would have to hook it up to the smoke machine but just or that its 135 bucks!! this sucks
