3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hey guys I had a headlight go out and bulb was good on a 2006 Dodge , they had to go through TICM ( fuse box ) under hood and like re-boot, can a normal non tech do this? Is this what yall are discusssing?
bulbs not working due to TIPM issues are a bit different from what this thread is about. most guys like to reset the PCM to clear CEL/MIL and erase DTC or they do it to make the PCM relearn the driving habits.
In another thread, it says to make sure you reset the ECM after any TB or EGR cleaning or replacement...i cleaned the TB like a month ago and everything worked perfectly fine, but this morning (10 degree weather) my ETC blinked and the pickup went into limp mode...could this be due to not rebooting the system, and if so how do i do this?
2004 Ram 1500 5.7 hemi
Thanks
I tried to reboot mine 06 1500 5.7 and i had the same problem as in the start of this post, where i only heard one chime and it was the air bag. I pulled #31.
