L.E.D. Brake Light Issue... Any suggestions would rock!
Hey guys,
I have had LED tail lamps on the back of my truck for about 2 years now with ZERO issues...simple plug n play set up-
(Maxzone Depot part # 334-1909PXAS2C can be found at http://maxzone.com/maxzone09/viewpro...334-1909PXAS2C)
About a week ago the "Lamp Out" indicator kept going on and off, on then off, off then on, which resulted in a very annoying ding ding ding ding.
NOW, the lamp out indicator stays on... it appears the culprit is the back driver side brake light (Passenger side works perfect).
The symptom: When I hit the brake pedal... the brake light "Strobes". It does not light up, then after about 2 seconds, it gives a quick flash, then back out again for the whole duration that I hold the pedal down for.
I took the lamp out and straight wired it to an extra 12V battery I had and everything seems to work PERFECTLY. ALL of the fuses are good, so I am stumped.
Any insights would be appreciated
Thanks DF!
Thanks DF!
I plugged the driver side lamp into the passenger side...the problem carried over to the passenger side so I threw the OEM lamps back in just for the time being... They are working perfectly....
I am back to powering the culprit tail lamp directly from a 12v source. Again, lamp is acting perfectly when direct power applied to it. WEIRD!? The stock tail lamps are working perfectly as well. I'm beyond stumped
