Last edit by: IB Advertising
Browse all: Electrical Guides
- Dodge Ram 2002-2008: How to Replace Oxygen (O2) Sensor
Step by step instructions for the do-it-yourself repairs
oxygen sensor ??
#21
I did order a code reader yesterday LOL
off AMAZON, but didn't notice till I placed the order that its 14-21 days till it gets here ??
but do have one on its way
I am just hoping I get my new inspection sticker and it stays off till that happens
they charge me pass or fail so, non point in spending money twice if I can !
Thanks everyone for the help and info
much appreciate it!
much appreciate it!
#23
I don't understand, if they are able to tell you it is a potential oxygen sensor issue, there has to be a number showing. Like I said, an oxygen sensor doesn't typically throw a code immediately on startup, so I'm not convinced you have bad oxygen sensors.
Also FYI, only 2 of the 4 oxygen sensors would help with emissions, the other two only monitor the catalytic converter, they don't need to be replaced until they have failed completely, as they in no way control how the engine runs.
I'm sorry, but I can't hypothesize about what may be wrong without that code number. This is all you need to read codes, $15 and free shipping, it'll tell you what the engine code is:
http://www.amazon.com/Autel-MaxiScan...bd+code+reader
Or go to the Dodge Dealer, and get them to pull codes. Remember a code won't tell you what has failed, it will only point you in a general area, but it will never tell you definitively that Part X has failed and needs replacing.
In the end, it doesn't matter how you get there you just need to know what the exact code is to even start helping.
This statement is true,but the emission people want to see what the two rear sensors are saying since that is what your vehicle is emitting. They could care less how the truck is running, but they want to know how efficient the cat is and that's told by the rear sensor. Front controls engine function and rear monitors cat efficiency....and cat efficiency= emissions
#24
#25
they were and are Mopar OEM sensor's
I drove 500+ miles and then it tripped again
I just ordered two new rear O2 sensors(mopar one's) and plan to just replace them, and see
My inspection stisker doesn't run out till 8/14
so, will be bying time to make sure its not tripping still, as failing can turn into a pain in the A$$,
after I replace the rear 2, if it comes on again, will hit my dealer and see what they say
thanks for the continued suggestions
#26
