3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Just replaced the water pump in my 01 5.9. Started it and there was a couple drips hitting the ground of coolant. Once the truck warmed up it started pouring out. I went back checked all the bolts. On bottom left hand side of the water pump there was a loose bolt. So I tightened it and right as it felt like it was starting to get tight it would all the sudden get loose again. Any tips, tricks, or suggestions?
