Antifreeze Leak
Antifreeze Leak
Yesterday I discovered that my coolant was leaking. The temperature gauge started to go up so I stopped and had a look. The leak is coming from the pipe that comes out of the front of the engine between the alternator and the flywheel. The pipe is connected to a rubber hose that runs into the firewall and inside the truck. There are 2 hoses running side by side into the firewall. Can someone tell me what this pipe is called so I can try and order one as soon as possible and get a new one replaced.
