K&N CAI or should I get a different 1, Is there a Motor cover after CAI Install?
#21
I installed the S&B CAI today, it took about 2 hours with out rushing, I must say this Intake is very well made, and fit perfect. Nothing needed to be modified and the directions were well written. I have not taken the truck for a ride yet so I can not comment on sound but just starting it in the shop it sounds the same as stock I am sure that will change a bit when driving. I did leave the optional plug out of the bottom as they say this restricts flow and does not really add a lot of heat. I read people say they just removed 2 bolts on the wheel liner but I found it much easier to just remove them all and let it hang.
So far so good, I did add a Small K&N filter to the vent coming out of the Oil fill and plugged it at the S&B housing.
#22
#24
Took the truck out today, I don't really feel and difference in power or the way the truck runs. The sound is a little louder but annoying, it may be more noticeable pulling a hill with a heavy load. I wasn't really expecting a difference so i am not disappointed. I am very happy with the fit,finish and look of this CAI.
#25
Keep in mind K&N Intakes which are dyno tuned only give you 11hp on the high end, its maybe good for a tenth of a second overall, so a home made intake may not achieve those results. Its not that the K&N or your home made intakes are a sham, its that Dodge actually put a decent intake system on their engines already so theres only marginal room for improvement, but with that said the intakes usually do better if you have a free flowing exhaust. Getting more air in an engine does nothing if you can't get more air out of the engine.
#26
If you can hear the difference of a Cold Air Intake then your exhaust is stock or you got ripped on your performance mufflers lol.
100% truth. A lot of people don't realize that. Or the fact you will never really "feel" any power gains. Yes, it is noisier, that's the only reason I use them.
#27
#29
The tuner will make it a completely different truck, best bang for the buck hands down. I used an old Superchips 3815 tuner with the 91 octane tune and the amount of power the truck has is just immense, it screams. My single cab Hemi truck went from running a 7.18 second 0-60 to a 6.37 second 0-60mph. Quarter mile used to be 15.4 and now its down to 14.4 consistently and taking on cars half its weight instead of trucks.
One of my favorite things about the tuner is mph correction for tire sizes, I used my GPS along with radar road signs to verify my speedo and set it accordingly with the tuner. I also raised the rev limiter to 6150rpm and shift points by 5mph, and that got rid of the 2nd gear lag and now it literally jumps into second gear with force and pins you all the way to 100mph. I put the speed limiter up to the max of 140mph, fastest I've had it is maybe 128mph (estimated by rpms above speedo stop) which is absolutely screaming in a 5300lb vehicle and with a longer road and a driver with more nerve it could have definitely gone faster.
