HEATING PROBLEM 2002 RAM 1500
Old 02-14-2007, 10:31 PM
ericgrant4's Avatar
ericgrant4
ericgrant4 is offline
Default RE: HEATING PROBLEM 2002 RAM 1500
I need to know what the gurgling is. I have a feeling it has something to do with the problem. RAZ 123 any luck, you have the same symptoms I have, wondering how you made out.
Old 12-14-2007, 07:34 PM
mfd561's Avatar
mfd561
mfd561 is offline
I am looking for some help in replacing my heater core on 2002 1/2 quad cab.. anyone got any suggestions
Old 01-05-2008, 07:37 PM
vinmac02's Avatar
vinmac02
vinmac02 is offline
I have the same exact problem. I can hear the water when I start to move from a stand still and when I'm coming to a stop. I don't know what it is or how to fix it but i thought it would give you piece of mind knowing that you're not crazy and someone else has this problem. My heat is also the same way.
Old 10-30-2013, 01:27 AM
musky72's Avatar
musky72
musky72 is offline
Default RE:heating problem dodge ram
My truck has the same problem you had.No heat on drivers side and gurgles.Desperate to know what the real problem is,hoping I can easily fix it.
Old 10-30-2013, 02:54 PM
Prismatic's Avatar
Prismatic
Prismatic is online now
No heat on driver side + Gurgling = blown heatercore.
See here for pics when I did mine.
The gurgling is air being moved through the heatercore.
It's technically illegal to vent refrigerant into the atmosphere. You'll need to take it to a shop to have it recharged anyways, so go to a shop and ask if they'll recover the refrigerant as part of the recharge service.
Quick Reply: HEATING PROBLEM 2002 RAM 1500
