anyone install an electronic brake controller?
Old 05-02-2009, 01:36 AM
kxwhite's Avatar
kxwhite
kxwhite is offline
i put one in my 09 1500. i mounted it under the dash just to the right of my right knee. like sax said it is a real simple install.
  #22
Old 05-02-2009, 01:57 AM
BubbaRadioNetwork's Avatar
BubbaRadioNetwork
BubbaRadioNetwork is offline
Originally Posted by JC1390
The cubby hole is designed in such a way that I had to take my dremel and cut off both sides about 1.5" from the front and almost the hole top. It squeezes in there perfectly. I like the look of it...nice and clean. And if I ever sell the truck the piece shouldnt be too much $$ to replace.
I'm guessing you removed this to do the cutting. Does it just pop off with clips or is it screwed down. I have a Tekonsha Prodigy controller and it wouldn't fit in the stock cubby hole. I hadn't thought about cutting the inside of the pocket out. Good idea! I think the power pedal switch goes here if you have that option.
  #23
Old 05-02-2009, 02:10 AM
kxwhite's Avatar
kxwhite
kxwhite is offline
that cubby is there for the new 2010 2500/3500 brake controls. if you look at the new pics of the trucks they have a flush mounted brake controller installed in there.
  #24
Old 05-02-2009, 02:37 AM
BubbaRadioNetwork
I could have swore one of the trucks i test drove had a panel covering this area with a switch in it like the old power window switches. I just looked at the brochure online of a laramie and this area was open. So, where is the power pedal switch located on the 09's?
  #25
Old 05-02-2009, 07:56 AM
qicvick's Avatar
qicvick
qicvick is offline
I cheaked with my dealer and he said the pigtail was not included in trailer package anymore, they sell them for 29 dallars but I went to ebay and bought one for less than 10 dallars including shipping, it was brand new still sealed in the plastic bag, the seller had several more for sale including fords and chevys so he must deal in them, there were several listed about a month ago on ebay, mine was a buy it now for 6.95. Someone mentioned on this or the other board that he used to install them and used 3m tape instead of drilling holes and screws and never had a complant so I am going to try that.
  #26
Old 05-02-2009, 09:51 AM
72combo's Avatar
72combo
72combo is offline
I am glad I kept the ones from my older Dakotas bet they are the same
  #27
Old 05-02-2009, 10:02 AM
qicvick's Avatar
qicvick
qicvick is offline
http://cgi.ebay.com/ebaymotors/NEW-D...1%7C240%3A1318
if link works here is an example of ebay, I would have kept mine off the 04 , just assumed the pigtail was still included
  #28
Old 05-02-2009, 11:18 AM
Silver Shark's Avatar
Silver Shark
Silver Shark is offline
I got the pigtail from U-Haul for $6.95. I had to get the one for the 06-08 model ram but it is the same plug. Find a U-haul that does the hitch installs and they will have them in stock.
  #29
Old 05-02-2009, 11:54 AM
09 Ram TRX 4 Lover's Avatar
09 Ram TRX 4 Lover
09 Ram TRX 4 Lover is offline
They are a snap to install. Took mine from my 06 i traded in the 09 just plug it in and tied harness out of the way and mounted controller. If you look under the dash you can see the plug in area. I hate wiring but i did it. LOL
  #30
Old 05-02-2009, 09:38 PM
BubbaRadioNetwork
Do you use the white double sided foam tape or the thin gray moulding tape. I have some of both. I think the moulding tape would be stickier. I think I will try the tape method first before I cut up the cubby hole.
Quick Reply: anyone install an electronic brake controller?
