2011 RAM 1500 Rear End Recall Info
#41
Dealerships dont make any money being honest or knowing important information.
I will bet ANYBODY $100 dollar bill, that if you walk into ANY dealer, they wont even mention it...!
If they DO know, they wont tell you about it, because they want your money first.
#42
Rrt
hey there, just called my service department at my local dealership to check on my vin # and they told me this has already been done to all the trucks sitting on dealership lots here in canada or atleast in our area. i purchased my truck aprox 1 week ago and he checked my vin and it was already done and my truck was brought in from another dealer 9 hrs away so seems like they are on top of it to me. i still would like a bit more info on the problem and there cure but he assures me they will inquire more about it and let me know.
#43
To me, if they are just filling up a defective part with more fluid and leaving the plug too low, that is horrible. And that is what it sounds like they are doing to me. Am I wrong??? So, down the road, if I have it serviced somewhere and they guy servicing doesnt fill in the extra fluid, then I am screwed. That is why I am saying I want the correct height on that plug if I spend $35k on a truck. That is what I am wondering....if the fix is that they are just adding fluid, but not replacing the part then Dodge may have just lost a new customer. That is what I was asking...and again, I am not that technical when it comes to cars.
thanks
dave
thanks
dave
#44
Minor issue? Having a rear end failure sometime in the future due to some oil change mechanic not knowing this is probably the only rear end in history you can't remove the plug and the proper lube level is the bottom of the hole is a big deal to me (how big depends on where I am and what I'm pulling)
#45
i was also told today from my dealer that they also expect that they will see a true recall in a few months to rectify this problem but again dont shoot the messenger. just repeating what i was told. personally i hope they do something but i still find it hard to believe that even at the level the fill plug is at now that it doesnt get sloshed around in there enough to protect all the parts. i have bought lots of old cars and trucks and when i changed the fluid in the rear end they werent all full to the plug and they were still going strong with lots of miles on them.
#46
Rear end failure??? How's that going to happen? That's a little melodramatic, isn't it? You're entitled to your opinion, but the fluid level is sitting where it needs to be after the RRT and diff fluid doesn't boil off or need to be changed that frequently. Frankly, it's not a big deal, IMHO. YMMV...
Therefore, YES, rear end component failure is a possibility.
#47
#48
#49
why would i put a junkyard piece on on a new truck, possibly voiding my warranty, absolving dodge of any future liability. i can hear them now " We would rally like to help you, but when you changed the cover, we feel it wasn' t done correctly and that led to this failure......" that being said, we do have 100000 miles or five years to prove this issue will have long term affects. we /dodge either caught this in time or we will be getting new rear ends, good time for gear changing if you need to. either way i'm not loosing any sleep over this.
#50
thanks
dave
thanks
dave
we also have a jeepjk and 2004 grand cherokee, all chrysler products. here is what i learned, dodges are great trucks, most dodge dealers don't go out of their way to screw you, if my rear grenades, even if it was some how my fault, my dealer will most likley put it through under warranty. dodge as a company has always stood by their products far better than ford or gmc. dodge/chrsler has always been known for their rcalls,but very few if any are gov't mandated.notice toyota's last recall and how they kept it quite at first. the rust issue from the eighties seems to have returned as they have limited recall on their fj but they have this issue on a few of there other models as well, just walk around to their service bays and look at alll the frames they have install. you bought a very good product, from a reputable company. just drive and enjoy!
