Aftermarket Double Din Install
I installed a pioneer avic z120-bt. ounce you try to fit yours in you will be ablel to see what to cut. I used a drimmel , to cut mine. It worked out fine.
Everyone,
Feel free to let me know if you had any questions in regards to the deck install. I know I spent ALOT of time due to the fact that I did not read the instructions provided to me with my items. I am willing to assist anyone if asked. All in all, I am pleased with the results of the install.
Everyone,
I bought the Metra 95-6511 kit. I searched through some of the threads and someone else used this as well. You can get it where ever you would like. I got it from eBay for $14.00. I had to cut some plastic and metal in order to get the new deck in as it was bigger than the factory deck.
I just did the Avic-Z110BT install in my '11 ram 1500 reg cab. The usual cutting and shaving of the plastic on top. What i did find though, when installing the antenna cable adaptor from Crutchfield, is that it does not clip in all the way to the original antenna. There is a black plastic piece that inserts into the original lead and i thought it was supposed to lock in. In another forum, someone said to remove that clip and just insert the lead which is not the case here. If you do this, you will have a loose fit. I called Crutchfield and they were aware of this and sent me a photo of how its supposed to look, installed. It does not clip in, just a snug fit. They should have included that pic when i got the original kit and antenna and it would have saved me some time. They sent me a new replacement after i told them i removed and obviously damaged that black clip. Here is a pic of it installed showing it not going all the way into the original antenna lead. Showing the black clip inserted into the white plastic partially. it will not go all the way in and lock and that is normal.
im going to do this soon ill take pics for you guys(if yall tell me how to hookup the steering wheel controls for next song and volume)...also what screen did you use?...looks sick and this is the one thing ima do to mine for the interior along with a custom headliner
