Last edit by: IB Advertising
Browse all: Interior
- Dodge Ram 2nd gen turn signa, hazar, and barke lights diagnostics
Guide to diagnose trouble and recommended solutions.
Horn..wipers..turn signals..high beams..NOTHING!
#21
Nate makes good points. My experience with these type of electronics is that the weak point is where the connector is soldered to the circuit Printed Wiring Assembly (PWA). The mating connector and the weight of the harness put a lot of mechanical stress on the PWA and often cause cracked solder joints. Often one can make symptoms come and go by just simply grabbing the harness close to the PWA and wiggling it around. That is why I always recommend disconnecting the battery first, and then disconnect the harness from the module and inspect the pins (make sure no crushed or damaged pins from the original assembly), reconnect the harness and battery and see if it fixed the problem. Often this will fix the problem but for good measure, withe the engine running, grab the harness and move it around, if you can induce failures it can be cracked solder joints or weak crimps on the wires. The big issue with these problems is that they are often intermittent and sometimes just touching things makes the problem go away only to return some time later.
#22
on
Mikey, maybe not intermittent on your case but I'm starting to get your problem and the other post here mixed up sometimes. gr8rows seems to have some kind of intermittent issue with his. The resolution to both of these problems and the community posts will help someone down the road. Good luck on your truck getting ready on time for your roadtrip.
#23
Hey guys... Just got a call from the dealer, its going to be covered on warranty. They said a Multi-Function Switch (MFS) went out.. That's what controls the wipers, trac. control, invertor, high beams... Etc etc... Said it will be fixed by tomorrow. So I'll be picking it up sunday due to work. I'll keep y'all posted on if that fixes the issue.
#24
Your 100% right on that Chris, install any aftermarket part that is not OEM approved and the risk is all yours not the manufactures,like the saying says " you can pay me now or pay me latter " if you want piece of mind only put factory approved upgrades in your ride, I think it 's an expensive lesson we have all learned thinking we saved some bucks but in reality it cost us twice as much to correct the problems we caused.
#25
on
1 Post
From the 09 Service Manual
The Totally Integrated Power Module (1) (TIPM) is a combination unit that performs the functions of the Power Distribution Center (PDC) and the Front Control Module. The TIPM is a printed circuit board based module that contains fuses, internal relays and a microprocessor that performs the functions previously executed by the FCM.
#26
#27
I first thought of the Multifunction switch, but you said your horn didn't work as well as no brake lights and inverter so I canceled it out as a possibility because that does not control those parts. It must have been shorting other circuits out on the canbus line used to control those parts??
But still the horn/evic didn't work.... But maybe and hopefully the MFS possibly caused the horn/evic to stop working by something...? Hell electronics are weird to me...it's pure f!@%%^@ magic (PFM).
#28
on
I too was thrown off by the EVIC, Horn, Inverter and EVIC not working. Anyway, glad to hear Mikey will be getting his truck back soon.
from the manual;
DESCRIPTION
The multi-function switch is located on the left side of the steering column, just below the steering wheel. This switch provides the primary controls for the wiper and washer systems, the turn signals and headlamp beam selection. The only visible components of the switch are the control stalk (2) and control **** (1) that extend through the steering column shrouds on the left side of the column. The remainder of the switch including its mounting provisions, its electrical connection, and the turn signal cancel actuator are concealed beneath the shrouds.
The switch housing (2) and controls (1) are constructed of molded black plastic. Each of the switch controls has white International Control and Display Symbol graphics applied to it, which clearly identify its many functions. A single integral latch feature (3) and slide tabs on the switch housing engage channels and a striker that are integral to the left side of the mounting bracket that is integral to the clockspring (5) to secure the switch to the steering column.
The Steering Control Module (SCM) is an electronic circuit board and microprocessor internal to the multi-function switch housing. The switch outputs are internally connected directly to the SCM. An integral connector receptacle on the back of the switch housing connects the SCM to the vehicle electrical system through a dedicated take out and connector of the instrument panel wire harness.
The multi-function switch provides the vehicle operator with a control interface for the following functions:
from the manual;
DESCRIPTION
- Headlamp Beam Selection - The multi-function switch control stalk provides detent switching for selection of the headlamp HIGH or LOW beams.
- Headlamp Optical Horn - The multi-function switch control stalk includes momentary switching of the headlamp high beam circuits to provide an optical horn feature (sometimes referred to as flash-to-pass), which allows the vehicle operator to momentarily flash the headlamp high beams as an optical signalling device.
- Turn Signal Control - The multi-function switch control stalk provides both momentary non-detent (lane change) switching or detent switching with automatic cancellation for both the left and right turn signals.
- Washer Control - The multi-function switch control **** provides a momentary WASH position for washer system operation.
- Wiper Control - The multi-function switch control **** provides detent switching for two continuous wipe switch positions, LOW speed or HIGH speed and an intermittent wipe mode with five delay interval positions. The control **** also has a momentary MIST or pulse wipe feature switch position.
#29
Okay guys....got a call from the dealer this morning! They said everything works and it's good to go!!! I will be picking it up tomorrow morning...Everything was covered under warranty as well as the rental from enterprise. They said that the EVIC, turn signals, esp, tow haul, high beams all work now!
