Last edit by: IB Advertising
Browse all: General Overview
- Dodge Ram 2009-present: Recalls and Technical Service Bulletins
Important information to help you understand your Ram.
N08 Rear End Recall
#51
#52
#53
Truthfully I wasn't all that concerned about it, there are far more dangerous things to worry about on the road than this recall issue.
#57
No way you can remove a driveshaft install the retainer and install new propeller bolts in 15 minutes....
#58
Remove 4 bolts, check nut, put retainer on nut and reinstall 4 bolts. You could have a sip of coffee and still be under 15.
#59
09 sport quad cab 4x4. 45k miles 4-1/2yrs driving it.
had the recall done. mine was ok, but they autmatically fix it anyway they say?
anyway. while they were there i noticed my out put shaft seal was leaking. they also found a cracked weld on the yoke? so i got a new drive shaft, and input/output seals on the transfer case. all under lifetime.... anyone else seen this?
#60
Just got the retainer installed, fairly painless.
While I was there, I had them replace the plugs (OEM non-platinum) and service the transmission (new filter, fluids and seal) for $415 tax included - not a bargain, but not worth my time.
I'm just past 5yrs since date of manufacture and at 40K miles.
Battery kicked the bucket a month ago, btw.
Got the 5yr inspection coming up in June.
