Notices
Detailing Discuss detailing your ride inside and out here.
DIY: Polishing Headlights with Toothpaste
Old 05-03-2014, 12:31 PM
ProStreetDriver's Avatar
ProStreetDriver
ProStreetDriver is offline
Default DIY: Polishing Headlights with Toothpaste
Video Tutorial on how to polish your headlights with toothpaste. This method does actually work, but it can be very work intensive compared to my other method of wet sanding. This works similar as to applying a polishing compound because toothpaste does contain an amount of grit/abrasive material. If you do have any stone chipping or heavier scratches in the headlight, toothpaste will not remove that as this method takes the contour of the light surface. Wet sanding on the other hand does remove more material and skins over the surface taking down any high spots. Your choice of wax can also be applied in the end to protect the lights over a longer period of time and give them a deep shine. Toothpastes that contain more of a grit/abrasive feel tend to work better than the types that don't. The outcome of the final product will depend on how much time you are willing to spend, what type of toothpaste you are using, and what the severity of the hazing on your headlights is. This will also work on other lights around the vehicle such as fog lights, parking lights, and tail lights. This process will last for almost a year until they need to be revisited again (when applying a protective layer of wax).
Tools/Supplies Needed:
-toothpaste
-spray bottle with water
-lint free cloth
-wax and lint free cloth (optional)
Procedure:
-be sure the wash your vehicle or at least the front of your vehicle to ensure there will not be any debris contaminating during the polishing process
-using your choice of toothpaste, apply it to a lint free cloth
-spray the headlight with a mist of water if it dry, this is for lubrication and increase a finer polish
-rub the toothpaste using the lint free cloth into the light, ensuring you get the whole surface of the lens
-use vertical and horizontal directions, as well as circular patterns
-apply more toothpaste and water when needed
-when satisfied, rinse the front of your vehicle off with water
-make sure the lights and area around is dry, then apply wax to increase the shine and protect the lights over a longer period of time (optional)
Old 05-03-2014, 01:20 PM
PublicHair's Avatar
PublicHair
PublicHair is offline
Don’t forget to add a clear coat that’s UV protected.
Reason why headlights oxidize is due to the lack of UV protection. Cleaning the headlights, either toothpaste, wet sanding, mothers aluminum mag & polish - whatever - you’ll still need to seal the headlight otherwise the sun will simply just turn them again in a few months..
Old 06-24-2014, 12:17 PM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Dodge Forum Moderator
looks great.
Old 06-29-2014, 11:16 PM
thzpcs's Avatar
thzpcs
thzpcs is offline
I don't get why you'd spend all this time polishing them with toothpaste and get a subpar job when you can just do it the right way with a real kit
Old 06-30-2014, 10:56 AM
1969CoronetR/T
vaffanculo
Everyone has toothpaste.
Old 07-13-2014, 10:37 PM
LoveDodge123's Avatar
LoveDodge123
LoveDodge123 is offline
Nice work!
Quick Reply: DIY: Polishing Headlights with Toothpaste
